3ds model look
COW Forums : Zaxwerks
Bill Triplett
3ds model look
on Aug 29, 2009 at 1:50:11 am
I purchased a 3d model of a shield. It should look metallic, shiny. I have imported it into Invigorator. Doesn't look metallic. What should I try?
Joe Moya
Re: 3ds model look
on Aug 31, 2009 at 4:49:21 am
In Pro-animator...While in object mode, you selected all objects... then, go to material setup and apply to the "palette window?" the metalic materials available in the Materials tab.
... the key is being in the material setup window...
I am not sure this is the same in invigorator (although they are similar)... but, hopefully this will provide enough info. to help you out.
