Expressions problems in 3D
COW Forums : Zaxwerks
Christopher Rotter
on Jun 27, 2009 at 1:47:07 am
I'm hoping someone could help me, I have a invigorator object and I want to apply a loop expression as well as a delay expression so that the layer loops and the other invigorator layers do the same as in loop but also delay. The problem I run into is that I don't know how to apply this because I'm animating with three axis and when I apply the expression of loopOut to all three axis the loopOut expression doesn't work.
Edward Wu
Re: Expressions problems in 3D
on Jun 29, 2009 at 9:52:42 pm
Hi Chris,
I'm not well versed in writing expressions, but if you'd like you can send me the project file and I can take a look at what you are trying to set up, and also see if there are any workarounds to what you are trying to achieve.
My e-mail address is ed@zaxwerks.com
Best,
Edward
Christopher Rotter
on Jun 30, 2009 at 2:24:12 pm
I removed that part out of my project after doing a few changes.
