Layer Fit and Face - Camera Point of Interest
COW Forums : Zaxwerks
Hernan Retamoso
on May 13, 2009 at 9:44:27 pm
When apply this tools to face a layer, the camera's "point of interest" disappears. Even if it previously had keyframes.
any suggestions?
thanks
Hernan
Edward Wu
Re: Layer Fit and Face - Camera Point of Interest
on May 14, 2009 at 10:00:09 pm
Hi Hernan,
When the camera is oriented to the layer, it doesn't make use of the Point of Interest, which is why it disappears. Unfortunately, you will not be able to bring back the Point of Interest because of how the program works. If you still need the Point of Interest, you can try using the "Fit View By Translating" tool and you should be able to keep the Point of interest while the layer is moved to fit the camera.
Best,
Edward
Hernan Retamoso
on May 14, 2009 at 10:34:59 pm
Thanks Edward!
I needed to leave unchanged the layers distributed in 3d.
I solved the problem by using multiple cameras, with and without Point of Interest's keyframes.
saludos
hernĂ¡n
Hernan
Edward Wu
on May 14, 2009 at 10:52:00 pm
Hi Hernan,
Thanks for the update. Good to hear you were able to work around the issue!
Best,
Edward
