ProAnimator won't recognized my PSD files
COW Forums : Zaxwerks
Zeno Pierre
on May 1, 2009 at 2:20:23 am
Hi, All
I hare used ProAnimaor on several occasions and have had great responses from it.
But, this time, when I was trying to use it today, it won't recognize any of my Photoshop images. I'm trying to past a photo shop photo onto a vector shape also created in Photoshop but when I go to the retrieve the PSD file, the PSD file remains grayed out.
I was thinking that I needed to go back to Photoshop and recreate the PSD file to make sure that I saved it correctly but, then again, I've found that all of my previously created PSD files are now also grey out and I can't select any of them!
What in the world did I do wrong?
Help!
Edward Wu
Re: ProAnimator won't recognized my PSD files
on May 1, 2009 at 11:23:11 pm
Hi Zeno,
If you are working with ProAnimator on Windows, one of the things that happens is when you are opening a texture map, it will ask for the file type that you want to open. Make sure to choose that you want to open a Photoshop file, and you should be able to select the Photoshop file. It's possible that your last texture map selection was a "jpeg" so it is still looking for "jpeg" files to open.
Hope this helps.
Best,
Edward
