Invigorator Pro installproblems
COW Forums : Zaxwerks
envision! Film and Video
on Apr 25, 2009 at 2:23:21 am
Having trouble installing 4.5.1p in After Effect. When I drag the folder to the AE plugins, I can open it up but have no object or material swatches. I read the install document but still can't seem to get it to work.
Edward Wu
Re: Invigorator Pro installproblems
on Apr 27, 2009 at 5:48:30 pm
If the object and material swatches did not load up with 3D Invigorator Pro, reset the swatches and you should be able to see the swatches. To reset the object and material swatches, follow the instructions below:
If you are on a Mac: Find the "User > Documents > Zaxwerks" and delete the "3D Invigorator PRO" folder.
If you are on a Windows machine: Go to "My Documents > Zaxwerks" and delete the "3D Invigorator PRO" folder.
After you have deleted the 3D Invigorator PRO folder, launch After Effects. setup and launch Invigorator Pro, and you should be able to see your object and material swatches.
Best.
Edward
