ProAnimator Link Animation Question
COW Forums : Zaxwerks
Foucault Martial
on Apr 1, 2009 at 12:19:28 pm
Is it possible to do this task in ProAnimator :
I have a Logo with a ball inside what need to turn like a Disco Ball.
Is it possible to animate the ball (inside the logo)on the Y axis and in the same time to animate all the logo (the ball need to be linked to the logo movement)?
Actually, I haven't find any solution, to animate the Ball, I've created a New Track, but the ball is not link to the entire logo movement.
Thank for help.
Why not ? Pourquoi pas?
Win XP SP2
Ppro CS3
AE CS3
Edward Wu
Re: ProAnimator Link Animation Question
on Apr 1, 2009 at 11:01:05 pm
Hi Foucault,
Here is one way you can do this inside of ProAnimator:
If you have all your objects together on one object track, you can spin the "disco" ball with the tweak tools (Selecting Object Mode, holding down the "ctrl" key, and using the Object Tumble tool) at the ending pose, while using the Animation window to apply your object animations (Move XYZ, etc). This way, as you are moving along in your timeline, your objects are moving because you set up your animation in the Animation window, and in addition, during the transition, the the disco ball will spin because you tweaked the ending position.
Best,
Edward
