ProAnimator-Illustrator Pathfinder Problem
COW Forums : Zaxwerks
Ryan Broom
on Mar 24, 2009 at 5:33:59 pm
I traced out a picture of a television in Illustrator and used the the pathfinder tool to subtract the tube section from the main television body. When I import the Illustrator file into ProAnimator the tube section is not cut out. Is there something I’m doing wrong? Thank you for your help.
cowcowcowcowcow
Edward Wu
Re: ProAnimator-Illustrator Pathfinder Problem
on Mar 24, 2009 at 11:33:24 pm
Hi Ryan,
When you use the "Pathfinder > Subtract" tool to cut out a hole in the television, make sure you use the "Expand" command as well.
Once you use "Expand", you should be able to see the cut out when you open the Illustrator Object in ProAnimator.
Best,
Edward
Ryan Broom
on Mar 25, 2009 at 2:39:30 pm
That fixed the problem, thank you for the help.
Edward Wu
on Mar 25, 2009 at 4:25:14 pm
Not a problem. Thanks for the update!
