invigorator PRO 4.0 install problems
COW Forums : Zaxwerks
Scott Bryant
on Mar 20, 2009 at 2:05:59 am
Just installed invigorator pro on the computer. it accepts the un-lock code, but after that, I get a message that says:
"Invalid Zaxwerks Preferences Folder. Cannot open security file. program will be cancelled."
I've looked all through the folders that came with the disk, but don't see anything marked pref. not a file, a folder, nothing.
any idea what i can do to fix this?
Edward Wu
Re: invigorator PRO 4.0 install problems
on Mar 20, 2009 at 4:42:58 pm
Hi Scott,
This error message means that you are encountering a permissions issue, or you are not logged onto an administrative account.
If you are having this issue on a Windows Vista machine, then you are running into an issue with the UAC (User Account Control) feature. To fix this, disable the UAC and you won't have any installation issues. You can see how to do this from our help center link below:
http://zaxwerks.com/helpcenter/?page_id=100
If you are having this issue on a Mac, then you will need to enable permissions for your "Root Directory > Library > Preferences". For instructions on how to do this, please visit our help center page below:
http://zaxwerks.com/helpcenter/?page_id=129
Best,
Edward
Edward Wu
on Mar 20, 2009 at 4:44:38 pm
I'm sorry, the link for the Windows Vista help center was not inputed correctly.
The correct link is listed below:
Best,
Edward
