invigorator pro latest version?
COW Forums : Zaxwerks
tim bowen
on Mar 3, 2009 at 3:49:35 am
I'm running invigorator pro 4.5.1. Is this the latest version? Can't seem to find it posted anywhere on the website.
thanks,
tim
http://www.timbowen.com
Edward Wu
Re: invigorator pro latest version?
on Mar 3, 2009 at 6:01:59 pm
Hi Tim,
Yes, Invigorator Pro version 4.5.1 is the latest version of our software.
To check the latest releases, please visit our download page located under "Support > Download Software". There's a pulldown menu towards the bottom where it lists all our software, as well as their latest version numbers.
I've provided the download page below if you're interested:
http://zaxwerks.com/cgi-bin/download.cgi
Best,
Edward
tim bowen
on Mar 3, 2009 at 7:23:28 pm
just seems like it's running a little slow on my Intel Mac.
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.8 GHz
Number Of Processors: 2
Total Number Of Cores: 8
L2 Cache (per processor): 12 MB
Memory: 8 GB
Bus Speed: 1.6 GHz
Using After Effects CS3.
Edward Wu
on Mar 3, 2009 at 8:22:34 pm
Hi Tim,
There's a few settings you can check that might help speed up the program for you.
In the Invigorator interface, go to the Camera Mode, and check the renderer. The pulldown menu will either show "Invigorator Renderer" or "Hi-Quality OpenGL". If you are using the Hi-Quality OpenGL Renderer, try using the Invigorator Renderer. Most users usually find that this renderer performs better for them.
In addition, if you are working with a lot of objects, it's important to not lower the Draft Object Faceting value too much. By default, your objects will have a Draft Object Faceting setting of "3.0" and a Best Object Faceting setting of "0.5". The higher the value, the rougher the edges. You can lower the Draft Object Faceting to "0.5" or "0.1" to check what the edges look like when you are rendering. However, when working, keep the Draft value at "3.0" for optimal performance.
If all your objects have a setting of "0.5" of lower for the Draft Object Faceting, change the values back to "3.0" and the program should run a lot smoother for you.
Best,
Edward
