Pro Animator Crashes Upon Offset of Layer Map
COW Forums : Zaxwerks
Ong Joseph
on Feb 16, 2009 at 3:36:10 am
Hi all,
I need some help urgently. I have a basic 3d text set up which I imported from illustrator. I used the "punchy reflections" map as a layer map for the text. However, everytime I click and attempt to offset the map on the effects palette, After Effects would prompt me that there isn't enough memory to carry out task and proceeds to close down the program, only allowing me to save a backup.
I have tried purging but it does not help. After several attempts to restart the application, the problem still persists. Can someone help? I'm using version 4.3 of Pro Animator.
Thanks.
Regards,
Joseph
Matt Rhodes
Re: Pro Animator Crashes Upon Offset of Layer Map
on Feb 16, 2009 at 7:02:58 pm
Hi Joseph.
If you can, send me your project file (only the .aep file) and I'll take a look.
Also send me a few steps to follow.
Note that the current version of ProAnimator is v4.5.1. We suggest you upgrade (it's free) if possible: http://zaxwerks.com/download
Send files to: matt@zaxwerks.com
Thanks.
Matt Rhodes
Zaxwerks, Inc.
Ong Joseph
on Feb 22, 2009 at 2:45:12 pm
Thank You Matt. I've proceeded to upgrade my product and the issue seems to be solved.
Joseph
