Imported logo Problem
COW Forums : Zaxwerks
Ted Strickler
on Jan 30, 2009 at 5:36:44 pm
I havea flat BMP logo that I want to make 3d. I imported the BMP into Photoshop CS3 and created paths then exported as an Ilustrator file. Then imported that into ProAnimator. It imported ok but part of it is filled in. What can I do about that?
The spokes on the left part of the logo are filled in.
Ted Strickler
Re: Imported logo Problem
on Jan 30, 2009 at 7:36:27 pm
Here is the way it imports into ProAnimator. Compression is turned off during save in AI.
Serge Hamad
on Jan 30, 2009 at 9:20:14 pm
Hi again,
Import your ai file using the "Open AS Layers" feature. This should eliminate your problem when using PS to create paths.
Let me know if you still have problems.
Salut.
Serge
Invigorator/Proanimator Training: http://library.creativecow.net/articles/hamad_serge/invig_training.php
Ted Strickler
on Jan 30, 2009 at 10:17:54 pm
It imported good and looks almost perfect in edit mode but when I render a frame the inside of the wheel and some letters fill up with garbage and looks bad.
