layer map movement
COW Forums : Zaxwerks
michael montgomery
layer map movement
on Jan 19, 2009 at 3:07:14 pm
Hello- first post. I'm having issues in making my own graphics animate through the model like the embedded zw environments do. To put it another way, when I turn my title I want the environment reflected in it to stay put so it looks....like a reflection. If there is a tutorial or if I'm missing that magic setting I would appreciate anyones help.
M
Its always something.
Matt Rhodes
Re: layer map movement
on Jan 23, 2009 at 5:41:02 pm
Hi Michael.
Are you using your layer map as a reflection map?
If so, it should respond like one.
If you assign it as a color map, it will stick to the object as it rotates.
Feel free to send me your project file. I'd be happy to take a look.
Thanks.
Matt Rhodes
Zaxwerks, Inc.
michael montgomery
on Jan 23, 2009 at 5:46:30 pm
Ah. In the reflection map. I'll give that a try and report back. Thanks.
