Error Message When I Install Zaxwerks For AE CS4
COW Forums : Zaxwerks
Steve Framework
on Dec 12, 2008 at 3:00:34 am
I'm trying to upgrade my After Effects to CS4 (from Professional 7.0).
After I install the AE CS4 I'm trying to install Zaxwerks 3D Invigorator (because a project I'm working on is involved with it). The project when I call it up says I need to "install 3D Invigorator."
Then once I do so I'm getting an error message in AE that says: "CAN'T IMPORT FILE '3D INVIGORATOR AE PRO 4.0.9': UNSUPPORTED FILETYPE OR EXTENSION."
Any thoughts what I might be doing wrong? I'm following the install directions as indicated.
Thanks...
Steve Framework
Re: Error Message When I Install Zaxwerks For AE CS4
on Dec 12, 2008 at 4:43:20 am
NEVER MIND. I GOT IT.
Max Toperzer
on Mar 13, 2009 at 9:46:45 pm
How did you solve your problem?
