Illustrator problems
COW Forums : Zaxwerks
Chris McCullah
on Dec 11, 2008 at 11:01:53 pm
Okay...I'm trying to animate a full world map, where certain countries or regions will Z-axis out in time with the VO talking about that place. I found a vector file of the map in different colors, and I worked for a few hours on isolating and labelling the countries so I could grab them by layer name in ProAnimator, instead of by number. I saved it as AI, and turned off compression. But I get a *6 operation error when I try to open it in ProAnimator.
Any help would be appreciated.
Jon Okerstrom
Re: Illustrator problems
on Dec 12, 2008 at 4:01:39 am
Hi Chris,
Tell us more to help us diagnose the probem:
Which version of PA are you using? (Always check for the latest update on zaxwerks.com).
Which version of Illlustrator are you using - and have you tried saving the art in an older, legacy format?
Jon
