Render Farm problem
COW Forums : Zaxwerks
Russ Maehl
Render Farm problem
on Dec 11, 2008 at 5:22:46 am
I am on Intel Macs/Tiger, After Effects 8 and Invigorator 4.51.
Problem is with render across the 'watch folder' farm. The invigorator models which use mapped images (instead of layer map) are not making use of the texture and the animation is popping.
This is a complex build. I suspect that I should have applied the reflection map as a 'layer map', but too late for that. I found that I had to put a copy of the textures into the 'Zaxwerks Maps' folder of each computer on the farm manually so that it would be picked up.
Any advice on this?
