rendering orthographic view
COW Forums : Zaxwerks
Sney Noorani
on Oct 12, 2008 at 7:58:11 pm
is it possible to render the orthographic view to the comp in ProAnimator?
I'm a noob to it, so I may not know the obvious, i've got as far as importing my object, beveling, texturing, and now I just want an orthographic still...
every time I select render to comp, the image has perspective, but I want it to look beveled, textured, but 'flat'.
thanks in advance
Sney //
Jon Okerstrom
Re: rendering orthographic view
on Oct 16, 2008 at 1:04:11 am
Hi Sney,
You've hit on something that strikes me as odd, too. You can render to orthographic when PA is running as a standalone but the behavior isn't the same when you use PA as a plug-in for After Effects.
I'm not sure why, but I'll noodle it for a while. I also suspect Zax or Matt will fill us in.
Jon
