Illustrator curves gone wonky - Need Solution Fast!
COW Forums : Zaxwerks
peter menich
on Sep 28, 2008 at 11:21:57 am
Hey,
I've come across a problem with some extruded type using Invigorator Pro 4.
Please refer to this jpg...
http://www.zedzero.co.uk/zaxprob.jpg
I saved the Illustrator files as version 8, and imported them in to Invig.
As you can see; in the preview window the curves on the font are all hunky dory, but in the actual comp they're not!
I've tried dicking about with various settings and gotten nowhere.
I tried doing them as models through Cinema 4D and importing them, but that seemed to create even more pain.
I have a Tuesday deadline to deliver this project, so a solution would be a wonderful thing - otherwise I will have to start again from scratch in Cinema 4D.
Keeping fingers crossed.
Pete
peter menich
Re: Illustrator curves gone wonky - solved!
on Sep 28, 2008 at 11:48:04 am
At ease everyone,
I did some further poking and found that if I turn the draft settings on the object faceting up to 10, and best settings down to 0.1 it solves the issue.
A bit counter intuitive, as the preview window seems to do the opposite to what its doing in the comp window - as well as to get better quality you need to decrease the best setting!
ho hum.
Jon Okerstrom
on Sep 28, 2008 at 7:58:53 pm
Hi Peter,
Draft mode is meant for fast previews of the motion. Bigger numbers result in cruder shapes that render really quickly in preview mode.
As you've discovered, you can use a really small number in the "best" settings to get very smooth curves. If the curves still aren't smooth enough, you can type in an even smaller number like .01.
Jon
