Showcatcher not catching?????
COW Forums : Zaxwerks
rich huxley
on Sep 24, 2008 at 7:44:50 am
Hi everyone, I am trying to put a 3d model of a golf ball being hit around a golf coarse (which are 2d video footage looked off) The 3d model of the ball is no problem I am using a flat plane also in Invigorator to chatch the 3d shodow,
however before I switch the surface of the flat plane to the shadow catcher i see the shadow but when I change to the surface catcher surface
I loose it
I am using AF CS3 and Invigorator 4.3.2 on a Macpro 8core
Any help would be very appreciated as I am starting to go a little crazy
thanks
rich
rich huxley
Re: Shadowcatcher not catching?????
on Sep 24, 2008 at 12:04:43 pm
sorry, I meant SHADOW CATCHER
Matt Rhodes
on Sep 24, 2008 at 11:01:30 pm
Hi Rich.
This is likely a bug.
Try rotating your floor 180 degrees along the X axis.
This will flip the floor to point in a direction that the Shadow Catcher can handle.
Let us know if you have any other questions.
Matt Rhodes
Zaxwerks, Inc.
rich huxley
on Sep 28, 2008 at 9:43:36 am
Hi Matt
Thank you so much, Flipping the plane on the x axis 180 degrees has produced the shadow in shadow catcher mode
cheers
rich
