3 gigs
COW Forums : Zaxwerks
adeeb oberoi
3 gigs
on Aug 10, 2008 at 10:29:35 pm
Everywhere I read about the advantage of adding upto 3 gigs and changing the boot.ini file.
Can any one tell me if there are any negative side effects to this?
I have total of 3 gigs now but only 2 gigs for AE and I want to change the boot.ini file to 3 gigs.
Will an extra gig help? so total 4 on the computer but only 3 for AE?
Adeeb Oberoi
Matt Rhodes
Re: 3 gigs
on Aug 19, 2008 at 4:54:10 pm
Hello Adeeb.
There would be advantages to having more memory for AE (in particular, you'll be able to fit more rendered frames into memory, which may improve performance slightly).
In general, though, unless you're dealing with huge data sets (incredibly complex 3D Invigorator objects, very high-def images/movies, etc.), you won't see too much of a difference.
That's been my experience, at least.
Let us know if you have more questions.
Matt Rhodes
Zaxwerks, Inc.
Adeeb Oberoi
Re: 3 gigs
on Aug 31, 2008 at 4:53:26 pm
Hi, Thnx for the tip about the 3 gigs.
I want to change from 2 gigs to three gigs. I checked inf. on the web and understand that I can do this in the boot.ini flder.
I also understand that it can mess up the computer if you do it wrong.
Could you advice the correct way to apply the 3 gigs in the boot.ini folder.
Regards,
Adeeb Oeroi
