Rendering Errors Inside ProAnimator Using 3D Primitives
COW Forums : Zaxwerks
Ron Moore
on Aug 1, 2008 at 4:37:42 am
I've created a 3D primitive baseball as a part of a logo with the stitched seam a Photoshop .psd image applied as a new material. Everything looks great in the Preview window, right down to the spinning baseball inside the animated logo. However, when I go to render even so much as a frame, all I get is the white ball background from the .psd file but no stitches. As a matter of fact, any image file I attempt to map onto the ball as a new material will not render out, only the solid color materials that come with the program will show up on the rendered image. There must be something I'm missing.
Matt Rhodes
Re: Rendering Errors Inside ProAnimator Using 3D Primitives
on Aug 4, 2008 at 8:21:32 pm
Hi Ron.
Would you mind sending me your project file (and related textures)?
I'd be happy to take a look.
Also, make sure that you're using the current version of ProAnimator:
http://zaxwerks.com/download
Send files to: matt@zaxwerks.com
Thanks.
Matt Rhodes
Zaxwerks, Inc.
