invigorator HD
COW Forums : Zaxwerks
adeeb oberoi
invigorator HD
on Jul 28, 2008 at 5:06:15 am
I was wondering if I have to do a HD project, can I do it in NTSC widescreen and then before rendering change the comp settings to HD and then scale up the INVIGORATOR layer?
scott novasic
Re: invigorator HD
on Jul 28, 2008 at 5:58:17 pm
the answer is yes as far as I know. You cant "render out" your invigerator content, THEN scale it up, that will result in a softening of your image. If the non rendered invigerator file is present and "in place" in the new HD comp it should render out as clean and nice as your D1 comp.
Scott
SuperNova
Animation & Visual Effects
Scott Novasic
Los Angeles Ca
web:http://web.mac.com/finaleffects
