Error processing scene command << end >> for class << AnimSequenceParams >> at byte xxx
COW Forums : Zaxwerks
Michael Deley
on Jul 19, 2008 at 11:13:34 pm
After rendering a video file that is using ProAnimator plug-in in After Effects, I saved the project.
Now that I try to reload the project file I have an error message:
And then "After Effects error: crash occured while invoking effect plug-in "ProAnimator"."
I'm not sure that the error is linked with ProAnimator.
Editing the After Effects file with the MacOS textedit shows that the loop "begin AnimSequenceParams" has no "end AnimSequenceParams" but ends with "clumps 0.0ition" (and then: "begin AnimPose")
So I guess that my project file is damaged.
But is there a way to repair it (my tries to end the loop 'by hand' in textedit ended in "chunk problems" of "no valid file" for After Effects) ? With After Effects ? With a textedit ?
[And of course Auto-Save / Increment was of...].
