animating words instead of letters for text animation presets
COW Forums : Zaxwerks
Joe Moya
on Jun 23, 2008 at 3:48:26 am
OK, I give...
I have look every place... read everthing I could...
And... have not been able to find a way to make annimation presets change from animating each letter of a work to each work being animated.
At present, the only solution I have found is to create a new track for each letter for each word and apply the animation. Unfortunately, this is very time consuming and almost impossible to make words fall into place properly in a 3D area... the letters for each word are frequently out of line and not even.
Anyone have a solution or at least point me to a tutorial that will help create animated word groupings instead of each letter as standard for the animation presets.
Joe
Jon Okerstrom
Re: animating words instead of letters for text animation presets
on Jun 26, 2008 at 12:37:34 am
Hi Joe,
I believe your answer will be found in the advanced options.
Choose one of the transition segments in the timeline. Next, look for the transition grouping pop-up menu. You can choose to group your text by word, by paragraph and by many other options. Alternately, you could select certain letters and make a hard group out of that.
Does this help?
Jon
Joe Moya
on Jun 26, 2008 at 1:46:50 am
Thanks... that's it... except I found that it sometimes (for what ever reason) doesn't work and gives a "First select an object, then choose this command"... so, I have to go to the text part of the track and select the objects.
Joe
