Cylinder Appears As Square In AE
COW Forums : Zaxwerks
Gregory Kuhn
on Jun 17, 2008 at 8:25:51 pm
I have created a cylinder in 3D Invigorator Pro and applied a map to one side. But in AE it continues to show as a square. Does anyone know what the problem may be. When I put it in draft mode in AE, it shows the cylinder but not in full resolution mode.
Please help!
Greg Kuhn
Jon Okerstrom
Re: Cylinder Appears As Square In AE
on Jun 18, 2008 at 1:50:47 am
Hi Greg,
Be sure you're looking at best quality mode rather than draft and be sure the smoothness slider under "best quality" is at the small end of the scale. You'll get even smoother results if you type in a smaller number like .01.
Jon
