Invigorator flickers screen
COW Forums : Zaxwerks
William Nellam
on May 18, 2008 at 3:00:02 am
If I have the scene preview window open , Invigorator makes the menu bar of AE flicker. I have plenty of memory. I have no problem opening up the plugin and using it. Also I have no problems with Pro Animator. Is there a setting I should check?
Jon Okerstrom
Re: Invigorator flickers screen
on May 18, 2008 at 7:42:47 pm
William,
I haven't heard of this issue. Providing more info about software versions and system hardware may provide some clues.
Jon
William Nellam
on May 19, 2008 at 1:03:08 am
Windows XP Pro SP3
AMD 64 Processor 3800+ 1 GB Ram
2.41 Ghz
After Effects CS3 (Did it with previous version too)
Invigorator Pro 4.0
William Nellam
on May 21, 2008 at 1:19:38 am
Maybe I don't need Invigorator if I have Animator Pro. Maybe since they are both installed its causing an issue.
Jon Okerstrom
on May 21, 2008 at 2:11:42 am
Hi William,
I have no reason to believe one app would impact the other. By chance are you rendering interlaced video? If so, it can look like it "flickers" on progressive-scan monitors like your computer monitor. To see what's happening for sure, try watching your video on the intended device.
Jon
William Nellam
on May 21, 2008 at 9:53:09 pm
No this is not effecting the video I am creating. It like flickers the menu and the program controls like something is wrong. Like it wants to freeze up. But again since I have ProAnimator it does all the Invigorator does. So I guess I can just uninstall it.
Jon Okerstrom
on May 22, 2008 at 12:28:56 am
William,
You could uninstall, but I wouldn't suggest that.
ProAnimator and Invigorator share the same modeling and texturing abilities - for the most part. However, their animation controls and abilities are really not the same. Each has advantages in certain situations.
You might contact tech support for this issue.
Jon
William nellam
on May 23, 2008 at 11:56:38 pm
What can Invigorator do that Animator Pro cannot?
