Zaxwerks 3d invigorator slow!?
COW Forums : Zaxwerks
Tony Vega
on Apr 24, 2008 at 9:48:41 am
I have 3d invigorator 4.0.0 installed in ae cs3
everytime i use invigorator it goes slow and i cant work with it ,why?
Tony
Matt Rhodes
Re: Zaxwerks 3d invigorator slow!?
on Apr 27, 2008 at 5:32:58 pm
Hi Tony.
The default rendering mode for Layers in AE CS3 is Best mode. You may want to switch the Invigorator layer's rendering mode to Draft mode.
You may also want to consider upgrading to the current version of the Invigorator - v4.5.
http://zaxwerks.com/download
Let us know if this helps your situation.
Matt Rhodes
Zaxwerks, Inc.
Tony Vega
on Apr 28, 2008 at 8:10:52 am
yes i upgraded it to 4.5 and it workd very nice!
thank you very much
Tony
Sweden
Mountaga Dramé
3d invigorator: Problem with the color palette
on Sep 28, 2009 at 3:35:49 pm
Hello to all
I intall 3d invigorator 4.0.0 in after CS4 (English version) and since I have a problem with the color palette. Indeed I can not enter more than two numbers in the boxes (rgb) and it is even with proanimator.All options are in English except the color that is in French.
I installed Windows xp French version.
