Updating illustrator files
COW Forums : Zaxwerks
hamish boyd
on Apr 13, 2008 at 11:47:31 pm
Hi all,
In Invigorator Pro, how do you update the source illustrator file?
In After effects, if I want to re edit a source file I simply do what I need to do on the source file in Illustrator or photoshop then 'reload footage' to bring in those changes into AE.
I basically have a simple three line text with a graphic object all as one illustrator file.
I have need to tweek the kerning and the original colours. How can that be automatically updated in Invigorator.
Thankyou!
Serge Hamad
Re: Updating illustrator files
on Apr 14, 2008 at 2:47:38 am
When you open your ai file in Invigorator, you must check the Open As Layer box.
To update your artwork all you need to do is select it in the Set-Up window then click on the "Reload" button located in the object tab.
Salut,
Serge
Invigorator/Proanimator Training: http://library.creativecow.net/articles/hamad_serge/invig_training.php
Hamish Boyd
on Apr 14, 2008 at 5:31:45 am
aha... thankyou, I had found the reload button, but it was the way I had prepped the AI files that wasn't right.
Thanks again.
