multi core rendering?
COW Forums : Zaxwerks
wim roegels
on Apr 2, 2008 at 7:41:50 am
I am thinking seriously on buying a InvPro for AE.
But is it right that there is right now no support for multi processor rendering?
Is this planed ... because I am not that happy with the Render Performace if I have to turn off the multi core support.
Thanks in advance.
Ong Joseph
Re: multi core rendering?
on Apr 2, 2008 at 9:53:48 am
Just to add on, I'm currently using 3d layer warps version 1.3. It seems to be rendering very slowly although I'm running on a quad core. Does this product support multi processors?
Ken Latman
on Apr 2, 2008 at 11:37:10 pm
I don't believe ProAnimator as a standalone application uses multiprocessor support. If your using it as a plug-in, AE should be using it in multiple processors if you have that turned on or have Nucleo Pro.
It might as a standalone application address more RAM that AE currently does.
How long are your compositions? You might want to breakup your animations into smaller chunks. That is one work around.
