Can the dock panels problem be solved?
COW Forums : Zaxwerks
Ken Latman
on Mar 28, 2008 at 3:21:31 pm
I routinely forget that ProAnimator still has a little quirk if you don't have the panels docked in AE that you get some weird processing slowness an inability to use the plug-in properly without switching between other programs and back to AE.
Is this an issue that can be fixed in the next release of ProAnimator?
I have two monitors and I usually have the Render Queue panel and Info panel on the secondary monitor. For the time being I just set up another workspace preference and activate that, when I know I will be working in ProAnimator plug-in. This tends to work.
Matt Rhodes
Re: Can the dock panels problem be solved?
on Mar 28, 2008 at 4:34:27 pm
Hi Ken.
This should be fixed with the next generation of the software -- it's being worked on now.
We realize it's a hassle having to dock everything in AE, but we just couldn't get our dual-modal dialogs to work properly when panels were undocked.
Thanks.
Matt Rhodes
Zaxwerks, Inc.
Ken Latman
on Mar 28, 2008 at 5:01:47 pm
Thanks Matt. Look forward to it.
