3d warps
COW Forums : Zaxwerks
Ong Joseph
3d warps
on Mar 24, 2008 at 3:21:39 am
I need some urgent help. I'm animating a piece of paper flying from away a distance to slap on the screen. I managed the animation but then I realised that the graphic was blur, it shouldn't be right? I used a precomped (1042x2185) a "brochure" then applied 3d warps to it in a (720x576) comp.
I unchecked the effect and scaled up the comp and there was no such issue. Can someone please help? It is greatly appreciated.
Joseph
Jon Okerstrom
Re: 3d warps
on Mar 25, 2008 at 12:48:24 am
Hi Joseph,
What are the camera settings you're using? Are you using the comp camera? Are you wanting a depth of field effect?
Jon
Ong Joseph
Re: 3d warps
on Mar 25, 2008 at 3:23:16 pm
Hi Jon,
I used the layer warps comp camera. I tried using the file without precomposing and adjusted the camera settings within and got it to be sharp. Think I got the camera position wrong causing the blur. Thanks for offering your help Jon, much appreciated.
Joseph
