Invig 4.5pro render speed drop over 4.0.9
COW Forums : Zaxwerks
Matt Lussier
on Mar 23, 2008 at 4:10:37 am
I have been playing with with Pro Invig 4.5
it seems to be extremely sluggish.
running xp pro32 - 4gig ram - qx9650 3ghz core 2 extreme - ae7.1 pro
I have a 1280x720 comp with many 3d ai layers of "extruded-transparency".
no motion blur... but very tight camera to create shards of varying transparent "glass walls" ...
it takes 1 minute 38 seconds to render 1 frame in v4.0.9pro
i switch out the invig folder and run v4.5 and the render speed drops to 3 minutes 24 seconds per frame.
anyone else experience such a noticeable drop in render speed?
any thoughts as to what the culprit might be?
did the same test in ae cs3:
v4.5 - 3 minutes 23 sec
v4.0.9 - 1 minute 32 sec
weird
Matt Rhodes
Re: Invig 4.5pro render speed drop over 4.0.9
on Mar 23, 2008 at 5:01:39 am
Hi Matt.
I can't think of anything obvious that would cause such a slow-down.
Would you mind sending me your projects (or a good test version of it)?
I'll do a few tests here.
Send files to: matt@zaxwerks.com
Thanks a lot.
Matt Rhodes
Zaxwerks, Inc.
Matt Lussier
on Apr 2, 2008 at 8:03:47 am
Hey Matt,
did you get a chance to try out my zax project file? did you experience the significant render lag i was mentioning?
Matt Rhodes
on Apr 3, 2008 at 9:26:59 pm
Hi Matt.
Sorry about the delay.
I rendered a second's worth of frames using Invig v4.0.9 and v4.5.
They both took the same time to render.
Let me know if you have another test. Maybe something else changed in your system between v4.0.9 and v4.5 -- or did you test it by swapping in/out the two versions of the Invig with the same scene?
Matt Rhodes
Zaxwerks, Inc.
