mirrored reflections
COW Forums : Zaxwerks
kurt murphy
on Mar 6, 2008 at 10:15:51 pm
Is there a way to achieve a true mirrored reflection of an environment with Invigorator? I have the reflection setting at 100, but I'm getting a blurred reflection of my environment on the flat front of my image. I checked some settings, but I didn't see anything on it.
I can put the environment on the face of the image, but it just pastes it on and won't react correctly as the 3D odject turns. I was thinking of distorting and Offsetting it as the 3D object spun, but was hoping there was an easier way.
Can you achieve a high polished mirror reflection in Invig?
thanks,
kurt murphy
Serge Hamad
Re: mirrored reflections
on Mar 8, 2008 at 12:16:42 am
Hi Kurt! Nice to see you around!
There are two things you must consider when working with reflection maps:
-To avoid the blurred look your object should have a very dark color. Black works best.
-To have more control on what is reflected on an object best is to use a comp as a layer map, add your environment to this comp and scale it way down until you see a clear reproduction of your map on your 3D object.
Does this help or did I misunderstood something?
Salut,
Serge
Invigorator/Proanimator Training: http://library.creativecow.net/articles/hamad_serge/invig_training.php
kurt murphy
on Mar 8, 2008 at 1:52:15 am
Serge,
Nope, you got exactly what I meant and once again helped me out completely. I really didn't see a way to do it and posted it on a whim. Serge, you're a treasure.
thank you,
kurt
