Map to .3ds file?
COW Forums : Zaxwerks
james williams
Map to .3ds file?
on Feb 20, 2008 at 4:02:21 am
I can easily put a map or video on any of animators primitive solids. I can't get a map or video to show up on a model i create and import as 3d studio file. I follow the same step by step procedure as with a primitive but it doesn't work. Am i missing something or is mapping to a 3ds file something that animator won't do.
J. Williams
Serge Hamad
Re: Map to .3ds file?
on Feb 21, 2008 at 9:19:42 pm
Hi James,
I don't use 3DS but what you need to make sure is that you are exporting your object including the UV coordinates.
If this doesn't help, you could send me the object (serge at nyc-visual dot com) I am sure we could make it work.
Salut,
Serge
"InvigoMany-Winter" is now available http://www.nyc-visual.com/invigomany-winter.html
Invigorator/Proanimator Training: http://library.creativecow.net/articles/hamad_serge/invig_training.php
James Williams
on Feb 26, 2008 at 7:54:42 pm
Hi Serge,
Thanks for the response. I looked further down the posts and found some info that got me on the right track. I also found out that Animator apparently doesn't like gray scale graphics. Every time I tried to put a photo(gray scale) on a plane it never mapped right. When I took it to RGB in Photoshop, it mapped perfectly. Wonder why that is?
J. Williams
