Plug-In
COW Forums : Zaxwerks
Donovan Werts
Plug-In
on Feb 15, 2008 at 7:42:51 am
HI, I just installed After Effects CS3. I have been using ProAnimator stand alone with no problem. I Open AE CS3 and follow instructions (make a new solid layer) and looked for the ProAnimator Plug-in under "Effects", it's not there.
I do see two files called After Effects plug-ins in the ProAnimator folder (regular plug-in and importer), and a folder labeled Plug-ins in the AE CS3 folders.
Is it as simple as dragging and dropping the plug-ins from the ProAnimator folder to the AE CS3 folder "Plug-Ins"? Or do you drag the whole ProAnimator 4.3.3 PC folder there instead? Not sure what to do. Thank you, Donovan
Topher Welsh
Re: Plug-In
on Feb 17, 2008 at 2:56:04 am
If you have the documentation for the ProAnimator plugin, it should tell you that you drag the entire folder into the Plugins directory...
If that doesn't work... I'm stumped.
Topher Welsh
Head Editor & Motion Graphics
http://www.scout.com
Donovan Werts
Re: Plug-In
on Feb 17, 2008 at 4:33:57 am
Thank you, I do have the documentation and searched the pdf. I finally found the answer in another post for After Effects. Donovan
