Reflector Flakey -- not updating despite script....
COW Forums : Zaxwerks
Brian Charles
on Jan 30, 2008 at 7:36:44 pm
I've made the Invigorator layer and the floor the same size as the comp and reflector will not update correctly when the camera moves.
I used the supplied script, and clicked the Update button in the Effects control to no avail.
I've uploaded a movie of a simple test here so you can see what I'm doing.
http://www.iomedia.com/zaxwerks/Refelctor_Problems.mov
Matt Rhodes
Re: Reflector Flakey -- not updating despite script....
on Jan 30, 2008 at 9:17:07 pm
Hi Brian.
Thanks for the thoroughly descriptive movie.
It seems that you're using another object to control the camera.
Reflector's Update uses the keyframes/values from the camera,
so I'm thinking that there's a problem grabbing the camera info.
You may have to directly set the camera keyframes in order to
get things to work.
Would you mind sending me your project? I'd be happy to take a look.
Send the .aep file (that should be all I need) to: matt@zaxwerks.com
Thanks.
Matt Rhodes
Zaxwerks, Inc.
