Reflector and Invigorator using Comp Camera: Limitation??
COW Forums : Zaxwerks
Brian Charles
on Jan 30, 2008 at 12:16:37 am
When I use the Comp Camera in Invigorator then create a floor and apply Reflector to it the reflection is skewed. I have "Hide 2D Layers" unchecked.
Turning off the Comp camera and updating Reflector shows the reflection in the correct perspective.
Is this a limitation of Reflector? Or am I missing something?
I couldn't find anything about this in the documentation.
Matt Rhodes
Re: Reflector and Invigorator using Comp Camera: Limitation??
on Jan 30, 2008 at 6:02:35 am
Hi Brian.
Make sure your floor layer has the same aspect ratio as your Invig layer -- which should have the same aspect ratio as your Comp.
Unfortunately, when those don't match, skewing can happen.
Let us know if that helps.
Matt Rhodes
Zaxwerks, Inc.
Brian Charles
Re: Reflector and Invigorator using Comp Camera: Thanks
on Jan 30, 2008 at 4:16:26 pm
Thanks for the info. I may have read this somewhere but had forgotten.
