Raytracing in 3D Invigorator tutorial question for Jon
COW Forums : Zaxwerks
John Qoyawayma
on Jan 28, 2008 at 10:52:21 pm
In trying the Raytracing in 3D Invigorator tutorial, AECS3 informs me that the 3D Invigorator is missing. I do own Proanimator was wondering if there a means to "relink" an effect like you would with footage?
Jon Okerstrom
Re: Raytracing in 3D Invigorator tutorial question for Jon
on Jan 29, 2008 at 3:58:49 am
Hi John,
You can transfer 3d objects between Invigorator and ProAnimator by exporting the zxo format. Invigorator and ProAnimator can't open eachother's projects beyond that.
You should be able to create the same elements in the tutorial with ProAnimator, however. In both Invigorator and ProAnimator, the key thing is to establish a ground plane and keep the objects from crossing over onto the other side and intersecting with eachother.
Jon
John Qoyawayma
on Jan 30, 2008 at 12:06:12 am
Would the Zaxwerks reflection plugin make this tutorial obsolete then? I think I can hear my wallet opening.
