3D Grid and Layer Warp scene data error
COW Forums : Zaxwerks
Brian Charles
on Dec 31, 2007 at 8:10:31 pm
As soon as 3D Grid Warp or Layer Warp are applied I get the following error:
"Warning: Recovering from scene data error for command
<< AlertUsersOfOffScreenWindows>> for class <> at byte 908"
After dismissing the warrning dialog the effect seems to function until I attempt a RAM preview when After Effects hangs and must be force quit.
This is After Effects 8.0.1.8 on OS 10.4.11 on a Mac Pro.
Zax Dow
Re: 3D Grid and Layer Warp scene data error
on Jan 2, 2008 at 2:56:43 am
Hi Brian,
Let's simplify things to see where we stand.
- Please make a DV sized comp
- Make a comp sized solid.
- Apply the Grid Warp effect to the solid.
Does it work?
If it does then what's the difference between this project and the one you're having trouble with.
If it doesn't let me know. Write to zax@zaxwerks.com
Best,
Zax
