Reflector Crashes Mac AE CS3
COW Forums : Zaxwerks
Brian Walsh
on Dec 3, 2007 at 11:29:05 pm
I just bought a 24" iMac, 2.4GHz, 4GB RAM, and won Zaxwerks Reflector at last week's AENY. I am running Leopard, 10.5.1, and After Effects CS3 version 8.0. I've tried using refector twice now, and it has crashed after a few minutes, each time, just after hitting the Update button (to update the reflection). Any ideas, anyone?
Matt Rhodes
Re: Reflector Crashes Mac AE CS3
on Dec 4, 2007 at 1:18:26 am
Hi Brian.
Can you send me your Reflector project
and give me a few instructions to follow
in order to replicate the problem?
Send files to: matt@zaxwerks.com
Thanks.
Matt Rhodes
Zaxwerks, Inc.
evangary
on Dec 5, 2007 at 3:25:15 pm
I am interested in a solution as well; I am running CS3 and Reflector on a Core 2 Duo with 4 GB Ram. I posted a question earlier, but have not received a response!
Zax Dow
on Dec 7, 2007 at 9:59:00 pm
Someone else had this trouble and discovered that by turning on the Multiprocessing option in the AE pref, he regained stability again.
Brian Walsh
on Dec 8, 2007 at 12:20:53 am
I'll try that out and let you know how it works. Thanks.
evangary
on Dec 8, 2007 at 1:27:56 am
Tried as suggested, did not work for me. Running on Windows XP platform.
Also, when I add a Proanimator layer, the reflection doesn't always show up and AE crashes after awhile. The error message says:
After Effects error crash occurred while invoking effect plug-in 'Refelctor'.
This happened in AE 7 also.
evangary
evangary
on Dec 8, 2007 at 11:44:12 pm
Solved the problems. Don't know which of the following actually did it. Set the hardware acceleration in Windows XP SP2 to about half (found a thread from searching this forum.) Also, re-installed ProAnimator. One or both of these solved my problems.
evangary
evangary
on Dec 8, 2007 at 11:44:39 pm
evangary
