AI from PS
COW Forums : Zaxwerks
Ryan Hodges
AI from PS
on Nov 25, 2007 at 8:25:56 pm
i continue to get an error when trying to import an AI file into proanimator. its not a complicated logo. i have it in PSD and export the paths to illustrator and can even reopen the ai in coreldraw (thats what i personally use for vector art). but when i go to import into proanimator it always gives the error that there are no usable vector paths or something like that. please advise.
Ryan Hodges
Re: AI from PS
on Nov 26, 2007 at 4:13:49 am
update on this:
i installed illustrator and successfully imported my logo. problem was when i fill in the areas that are to be solid it covered other areas, for instance a circle inside a triangle should be cut out rather than just on top of it. i know how to do all of this in corel, but not in illustrator. how do you do "front minus back", etc, if you can that is. once i imported my somewhat jacked logo into proanimater i had a front face not attached to the back face so when i went to increase the width it just increased the seperation between the two faces, what did i do wrong?
John Dickinson
Re: AI from PS
on Nov 27, 2007 at 9:15:12 am
In Illustrator you create a "compound path". Basic Illustrator preparation for ProAnimator is part of the new Zaxwerks ProAnimator training (http://zaxwerks.com/dvdtraining/index.shtml).
JD
John Dickinson
Motionworks
http://www.motionworks.com.au
