Output for high definition
COW Forums : Zaxwerks
joselo
on Nov 19, 2007 at 3:01:07 pm
I
Jon Okerstrom
Re: Output for high definition
on Nov 20, 2007 at 1:44:38 am
Hi Jose,
It's certainly possible to render ProAnimator movies in high-def.
Does your projector output 720p or 1080p or 1080i formats? Knowing that - as well as your playback device and medium will give you the answers you need.
Without knowing that, my assumpion is you'll want ot render your movies at 720p, which requires 1280x720 pixel resolution, non-interlaced.
1920x1080 is another common format which results in much larger files, but it may be overkill depending on your output device. 1080p or 1080i are both doable, assuming you have a playback device.
For more on HD formats, follow the link below:
http://www.adobe.com/designcenter/productionstudio/articles/prs1ip_hdprimer...
Hope this helps.
Jon
