version 4.3.2 on ae cs3, problem
COW Forums : Zaxwerks
Rick Neely
on Nov 13, 2007 at 9:43:24 pm
Hi, just bought and installed proanimator 4.3.2 on my AE CS3 (running power pc dual 1.8 mac g5, tiger)
It installs fine and I see it in effects. When I apply to a solid layer, I click on the proanmator plugin box in the effects palete to edit, I type in text and then the main proanimator windows appears and then flutters a moment every two seconds. I can do nothing- I can edit in proanimator, I can't exit an go back to after effects, I have no choice but to do a force quit.
Can I get some help fixing this 'bug'"?
Rick
Matt Rhodes
Re: version 4.3.2 on ae cs3, problem
on Nov 13, 2007 at 11:50:16 pm
Hi Rick.
Do you have any floating panels in AE? ProAnimator doesn't work properly if you have any floating panels.
A solution is to make sure all of your panels are docked before opening the PA Set-Up window.
Let us know if you still have a problem.
Matt Rhodes
Zaxwerks, Inc.
serge
on Nov 13, 2007 at 11:54:06 pm
Matt, Could you please check your mail? I just sent you an e-mail.
Sorry to interrupt this thread this way. I just wanted to get your attention.
Salut & sorry again.
Serge
Rick Neely
on Nov 14, 2007 at 1:25:56 pm
Matt,
that trick worked. Weird little quirk but at least I'm running. thanks!
Rick
