rotating text around a circle
COW Forums : Zaxwerks
matzunaga
on Nov 7, 2007 at 1:04:09 am
Hi
I am using ProAnimator as a plugin in after effects. I need to animate the worth earth
It needs to come in straight from the left
and as it gets to the right start to turn (bend)
as if rotating around the earth
I have the animation where the word comes from the left no problem
when it gets to the right it starts to bend but it bends from both sides or the center (how ever you want to see it)
and the animation first bends the text and then it starts to rotate
I need it to bend only from the right and start its rotation
and after it finished doing its 360
to "unbend" from the left
Hope you understand
Thank for any help
Juan
