Flicker
COW Forums : Zaxwerks
Henry_B
Flicker
on Oct 27, 2007 at 2:59:43 pm
ok, i have a comp in after effects, i have my preview resolution at half and i see a lot of flickering in my proanimator 3d text, first i thought it was a preview problem but when i rendered my comp the flicker was still there, not as much as in the preview, but still was there. here are 2 files where you can see what im talking about
http://www.promograf.com.mx/cow/Compflicker.mov
in this example the flicker starts almos at the end of the 2 text animation
http://www.promograf.com.mx/cow/Compflicker2.mov
and in this example the flickes is almost at the end of the animation
thanks in advance..
Serge
Re: Flicker
on Oct 29, 2007 at 3:22:25 am
Hi Henry,
I had the same issue a couple of times when using several Invigorator instances. Are you doing so?
I could eliminate the problem by trashing the prefs.
Are you using presets maps?
let us know if this works for you. BTW. Make sure you are using the latest version of ProAnimator.
Salut.
Serge
Henry_B
Re: Flicker
on Oct 30, 2007 at 4:22:36 pm
hi serge, thanks for your answer, well, yes, im usin several instances of proanimator, i have several solids with PA aplied to them, if thats what you mean.
how can i trash the prefs??
and yes, im usin presets.
thanks in advance
Serge
Re: Flicker
on Oct 30, 2007 at 8:16:19 pm
Hi Henry,
Your prefs are located in the main ProAnimator folder.
Just make sure before trashing them to have your license handy as you will have to use once you restart.
Before trashing anything you could also try to use your preset image as a layer map and see if this works. You can find your images in the environments or Zaxwerks maps folder depending on what kind of preset you are using. This trick worked for me once. I think that Invigorator had trouble loading my TGA file.
Last but not least I would generally advise you to pre-render some of the ProAnimator layers with an alpha and subtitute the movies with your ProAnimator layers.
I hope this helps.
Salut.
Serge
"InvigoMany" is back in stock! http://www.nyc-visual.com
Invigorator/Proanimator Training: http://library.creativecow.net/articles/hamad_serge/invig_training.php
Henry_B
Re: Flicker
on Oct 30, 2007 at 8:54:04 pm
thanks serge! i think that rendering each instance will be the fast solution, ill try the other when i finish this proyect, thanks for the advice !
