Adobe Illustrator CS3 and Invigorator
COW Forums : Zaxwerks
FeelTheLove
on Oct 13, 2007 at 9:36:20 am
What version of invigorator/proanimator must you have to import from Adobe Illustrator CS3? Thanks for your help. By the way I love invigomany!!!
Jon Okerstrom
Re: Adobe Illustrator CS3 and Invigorator
on Oct 13, 2007 at 12:24:26 pm
Hello FeelTheLove,
You can use any version of Invigorator or ProAnimator. However, if you're using an older version, you'll need to export the art in a legacy Illustrator format. In any case, when you save the file, be sure the "use compression" box is unchecked.
Does this help?
Jon
FeelTheLove
on Oct 13, 2007 at 6:03:42 pm
Thanks Jon...that did the trick.
