Correctly importing Illustrator files into Invigorator
COW Forums : Zaxwerks
Fongaboo
on Oct 2, 2007 at 10:31:24 pm
I'm importing an Illustrator logo but its closing up the hole in my zero and connecting a 'web' between the base and the beak of the number one, so it looks like a triangle of sorts.
Its been a while since I have used 3D Invigorator regularly. I remember there being some way to fix this - either a checkbox in Invigorator or a attributes to set in Illustrator. Anyone got a quick tip?
I am running AE6.5 with InvigPro 4.x.
Jon Okerstrom
Re: Correctly importing Illustrator files into Invigorator
on Oct 3, 2007 at 2:02:33 am
Sure thing.
Look at the doc in Illustrator. Be sure you've created a compound path in the zero by selecting the inner and outer path and choosing compound path>make.
As for the number one, it sounds like you have an open path for some reason. Select the number 1 object and use the pathfinder tool to unite or close the open path.
Let us know if that helps.
Jon
