Easy question..
COW Forums : Zaxwerks
Betty Boop2
Easy question..
on Sep 24, 2007 at 1:42:01 pm
Been away from Pro animator for a while and forgot some stuff.
So I brought in a three layer logo from Illustrator just fine.
The layers are not as big (bounding box) as my comp
My composition is 720 x 486.
Is there a way to enlarge the bounding box to my comp size?
-jay
Jay Thompson
Thompson Visual Design & Storytelling
7 Marjean Ct.
Kirkwood, MO 63122
Matt Rhodes
Re: Easy question..
on Sep 24, 2007 at 2:07:45 pm
Hi Jay.
If I understand your question properly, you can make your
objects larger in the Comp by opening the PA Set-Up (Options)
window and moving your camera closer to the objects.
Does this answer your question? Let us know if it doesn't.
Matt Rhodes
Zaxwerks, Inc.
Betty Boop2
Re: Easy question..
on Sep 24, 2007 at 2:30:17 pm
No...I don't think so.
I need the imported illustrator object to be free of it's bounding box and be comp size.
-jay
Betty Boop2
Re: Easy question..
on Sep 24, 2007 at 2:39:35 pm
Found it. It's the collape transformations and/or contentiously rasterize layer needs to be clicked on in the AE comp window.
-jay
