Anti-Aliasing, am I misisng something?
COW Forums : Zaxwerks
drar
by
on Sep 11, 2007 at 6:05:19 pm
hey there, I am just making asuper quick animation in zawerks. I brought in some text from .ai and applied one of the pre-set Object Styles to it. real simple. I did this three diffrent times with three diffrent object styles and I have the same problem every time. Most of the pre-sets have a black out line or something to it. When I do my final render and play it back on my monitor it has very bad aliasing. fliker on the screen. I don't know how to smooth it out. am I missing something? is there a setting under the object tab I should play with to fix this? it seems the pre-sets should be NTSC ready but I can't get it to look smooth when it animates.
Under object faceting I have it at the fefaults (Draft: 3
Best 0.5)
any ideas?
thanks!
~Chandra
Matt Rhodes
Re: Anti-Aliasing, am I misisng something?
on Sep 11, 2007 at 7:59:34 pm
Hi Chandra.
The output in the 3D Preview window is not anti-aliased. It is for preview purposes only.
In order to achieve better output, you'll have to render your scene out to a movie.
If you have rendered to a movie and still see the aliasing, let me know. You may have to adjust your anti-aliasing settings.
Also, if you can send me (or post to the forums) a screen shot of your problem, it would be helpful. Send files to: matt@zaxwerks.com
Thanks.
Matt Rhodes
Zaxwerks, Inc.
