layer map glitches
COW Forums : Zaxwerks
Laurie Pepper
layer map glitches
on Sep 2, 2007 at 12:20:21 am
What am I doing wrong?
I'm building a bunch of little shacks on a hillside in AE Using AE7.
They don't require a lot of detail.
I'm creating a little house-shaped ai
I'm creating a little roof-shaped ai
I put 'em both together as zax solids, and they look fine.
I apply a texture to the roof. Fine.
I apply a layer map to the front of the "house." Fine
I attempt to apply another layer map to the side of the house.
Whoooops. Old layer map on FRONT is replaced by the new layer map (#2).
Even tho I click the right little boxes and so on. I think.
BUT if I just apply a *color* to the side, there's no problem. Front keeps layer map. Side turns correct color.
Also, btw, ae keeps crashing when invoking zaxwerx. So I try to keep each zaxwerx model in it's own project and do all the rendering and make a .mov or a still before importing it into the comp I want to use it in. A pain.
I've uploaded a sample comp. Here's the little project. It crashed a couple times, too.
Please help. This layer map thing is an ongoing problem.
Go to ftp://anonymous@straightlife.info@straightlife.info. When prompted for password just hit okay. download the houseproject zip. THANKS, THANKS. L.
http://straightlife.org
John Dickinson
Re: layer map glitches
on Sep 2, 2007 at 11:37:05 pm
Not able to access that link...
JD
John Dickinson
Motionworks
http://www.motionworks.com.au
Laurie Pepper
on Sep 2, 2007 at 11:55:07 pm
Did you try
And then when prompted for password, just hit okay???
It works for me & I had a friend try it and it worked for him...
thanks, please try again? L.
John Dickinson
on Sep 3, 2007 at 12:02:33 am
no luck from here. Must be the internal firewall.
JD
John Dickinson
Motionworks
Laurie Pepper
on Sep 3, 2007 at 12:08:43 am
NERTZ! Somebody else? Please?
John Dickinson
on Sep 3, 2007 at 12:32:52 am
How big is the file, maybe you can email it?
John Dickinson
Motionworks
Laurie Pepper
on Sep 3, 2007 at 12:36:00 am
Small. Try this first. If it doesn't work give me your email!
http://straightlife.info/downloadpage.html & then click on the Link that says AE ????
