Duration animation Problems
COW Forums : Zaxwerks
joselo
on Aug 8, 2007 at 6:01:30 am
I'm working for the first time with proanimator. Working in after affects. I'm working with a long animation. My problem is that i can not make the duration of the animation longer than 30 secs (i'm not able to type in a new duration in the animation window). When i use the proaniamtor jus by itself (not with AE) it is posible to type in a new duration . Why?.... I'm working with sound so i need to be able to work through after effects. I'm just a beginner.... thanks for any help.
best
Jose
Serge
Re: Duration animation Problems
on Aug 8, 2007 at 5:02:04 pm
-Make sure that the duration of your composition is as long as needed.
-In the AE timeline your Proanimator layer should have the same length
-The Proanimator Animation timeline should then adjust automatically.
Salut.
Serge
INVIGORATOR-TRAINING VOL.1 soon available here: http://www.nyc-visual.com
joselo
on Aug 10, 2007 at 7:55:39 am
Thank you so much for the help. It worked! I'm just a begginer
Best,
Jose
